  New Posts New Posts RSS Feed - Dimensional Principles of IPC-7351B
drj-bbe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Topic: Dimensional Principles of IPC-7351B
    Posted: 04 Aug 2015 at 1:25am
Hello Tom,
There is a dimension "Amax" indicated in below principles of IPC-7351B, see below picture.
But it seems there is no drawing to define which size is for "Amax".
Could you please help on this question?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2015 at 6:08am
This condition creates a Outward L lead -
This lead style has a different calculation then the normal Gull Wing lead style:
Post Options Post Options   Thanks (0) Thanks(0)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2015 at 6:38pm
I have mark Amax and Smin below, is it correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2015 at 7:52pm
Please download the SMD Reference Calculator.
All values and dimensional assignments are displayed.
You can change the calculation values and observe the resulting land pattern results.
Download here -
Post Options Post Options   Thanks (0) Thanks(0)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2015 at 8:11pm
I cann't find dimension "A" mentioned above in SMD reference calculator. It seems only for chip component.
Could you tell me which size is for the dimension "A" ?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2015 at 8:27pm
Sorry for the late reply especially for such a simple question, it's been really busy lately.
Amax = the Lead Span
3D model created by Library Expert.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2015 at 8:57pm
This picture illustrates what the IPC-7351B text condition for Gull Wing lead is referring to.
When the Terminal Leads bend inward.
