  New Posts New Posts RSS Feed - Difference PROHIBIT_VIA_HOLE and PROHIBIT_VIA
Olaf.MuellerAE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Olaf.MuellerAE Quote  Post ReplyReply Direct Link To This Post Topic: Difference PROHIBIT_VIA_HOLE and PROHIBIT_VIA
    Posted: 10 Feb 2021 at 2:04am
Hello all,
Can someone explain me the difference between PROHIBIT_VIA and PROHIBIT_VIA_HOLE?
These keep-out layers come up during eCADSTAR export.
For me each PROHIBIT_VIA is also a PROHIBIT_VIA_HOLE. I see no sense for a single PROHIBIT_VIA_HOLE area.
Best Regards,
Olaf
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2021 at 9:01am
I have the following definitions for you:
- Via Keepout: prevents a via being placed on that layer.
- Via Hole Keepout: allows a via to be stop on that layer, but prevents it passing through the dielectric layer below that layer.
As Via Hole Keepout prevents a via from going through the dielectric layer below it, it is not valid for the bottom layer due to having no dielectric layer below.
This function was not available in the older CADSTAR.
Best regards / Mit freundlichen Grüßen
Karl-Heinz Kluwetasch
Geschäftsführender Gesellschafter  |  Chief Executive Officer
