  New Posts New Posts RSS Feed - DFN  "L" "N" "M" values
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: DFN "L" "N" "M" values
    Posted: 23 Mar 2015 at 1:23pm
On a 2 lead DFN it looks like there are no values you can enter for the toe,side, and heel ? Is this correct ? Also the default values for density level for the Flat No-Lead Side length <1.6MM are all the same for "L" "N" "M". Is this correct ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2015 at 1:31pm
On all "Bottom Only" terminals, LGA, CGA, BGA, 2, 3, 4 pin DFN, PSON, PQFN there is no Toe, Heel or Side. There is a periphery, meaning that whatever the value is, it's the same on all sides.
And once a component package is less than 1.6 mm the 3-tier system is thrown out and only one pad size is preferred.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2015 at 1:33pm
Thanks Tom.
This page was generated in 0.363 seconds.
