  New Posts New Posts RSS Feed - Designator text generated even if don't want it
zentekfr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zentekfr Quote  Post ReplyReply Direct Link To This Post Topic: Designator text generated even if don't want it
    Posted: 19 Jan 2022 at 9:15am
[Footprint Expert Enterprise 2021.21]
Drafting options:
Silkscreen Outlines and Text > All density levels > Add Ref. Des. to Footprint: unchecked
Assembly Outlines and Text > Add Ref. Des. to Footprint: unchecked
When I generate the footprint, the Designator on the Silkscreen layer is not present (expected), but it is present on the Assembly layer (Stroke width: 0mm, Text height: 1.2mm - corresponding to the Nominal density whereas I'm generating the Least one).
Note that in Altium Designer, a text with a 0mm width is visible.
Here is an extract of the generated script:
// Create text object for .Designator
TextObj := PCBServer.PCBObjectFactory(eTextObject, eNoDimension, eCreate_Default);
TextObj.UseTTFonts := True;
TextObj.Layer := ILayer.MechanicalLayer(25);
TextObj.Text := '.Designator';
TextObj.Size := MMsToCoord(1.2);
TextObj.Width := MMsToCoord(0);
TextObj.UseTTFonts := False;
NewPCBLibComp.AddPCBObject(TextObj);
PCBServer.SendMessageToRobots(NewPCBLibComp.I_ObjectAddress,c_Broadcast,PCBM_BoardRegisteration,TextObj.I_ObjectAddress)
Is this a bug?
Justin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2022 at 9:18am
Remove the Mechanical Layer assignment in the CAD tool interface menu.
The Ref Des will not be processed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zentekfr Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2022 at 9:23am
Well yes, this workaround would surely work.
Thanks
