  New Posts New Posts RSS Feed - Custom/arbitrary pad shape?
mdevoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdevoe Quote  Post ReplyReply Direct Link To This Post Topic: Custom/arbitrary pad shape?
    Posted: 10 hours 52 minutes ago at 11:28pm
Is there any way to create an arbitrary pad shape for use in a pad stack?
I have a connector where the manufacturer recommended pads in the corners are "L" shaped. It's not a public part so unfortunately cannot share the datasheet.
I could realize this by splitting it into two rectangular pads, but thought I'd ask if there was any other option to natively generate a single pad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 15 minutes ago at 9:05am
Footprint Expert cannot do irregular shaped pads, but we build those footprints in a CAD tool and import the ASCII data into FPX file.
What manufacturer and part number are you looking for?
Maybe the Case Code in already in the POD database.
