  New Posts New Posts RSS Feed - Custom/arbitrary pad shape?
mdevoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdevoe Quote  Post ReplyReply Direct Link To This Post Topic: Custom/arbitrary pad shape?
    Posted: 9 hours 44 minutes ago at 11:28pm
Is there any way to create an arbitrary pad shape for use in a pad stack?
I have a connector where the manufacturer recommended pads in the corners are "L" shaped. It's not a public part so unfortunately cannot share the datasheet.
I could realize this by splitting it into two rectangular pads, but thought I'd ask if there was any other option to natively generate a single pad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 7 minutes ago at 9:05am
Footprint Expert cannot do irregular shaped pads, but we build those footprints in a CAD tool and import the ASCII data into FPX file.
What manufacturer and part number are you looking for?
Maybe the Case Code in already in the POD database.
This page was generated in 0.594 seconds.
