Custom/arbitrary pad shape? |
mdevoe
Topic: Custom/arbitrary pad shape?Posted: 28 Jan 2026 at 11:28pm |
Is there any way to create an arbitrary pad shape for use in a pad stack? I have a connector where the manufacturer recommended pads in the corners are "L" shaped. It's not a public part so unfortunately cannot share the datasheet. I could realize this by splitting it into two rectangular pads, but thought I'd ask if there was any other option to natively generate a single pad.
Nick B
Posted: 29 Jan 2026 at 9:05am |
Footprint Expert cannot do irregular shaped pads, but we build those footprints in a CAD tool and import the ASCII data into FPX file. What manufacturer and part number are you looking for? Maybe the Case Code in already in the POD database. |
mdevoe
Posted: 29 Jan 2026 at 12:32pm |
Appreciate the feedback and good to know that it's an option! It's a unreleased, not yet publicly available part so I don't think it would be in the POD database. And unfortunately can't share drawings for it either. I may just manually create it for now.
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6088 |
Posted: 29 Jan 2026 at 12:39pm |
The best option is to build the basic pattern in Footprint Expert and then move it to your CAD tool to add the custom pad stacks.
Footprint Expert will auto-generate all the drafting outlines and create the standard pad stacks. |
