  New Posts New Posts RSS Feed - CSV Export of Library Data?
Evenkeel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evenkeel Quote  Post ReplyReply Direct Link To This Post Topic: CSV Export of Library Data?
    Posted: 17 Dec 2012 at 2:40pm
Is it possible to get a CSV export of the column data contained within the FPE.fpx library file?
A CSV (or any delimited text file) makes it easy to use grep to find a specific part using any of the data available.  I know that there is a search within FPX, but I do find grep to be faster.
Billy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 2:45pm
You can open any FPX file in Microsoft Excel and edit the file.
Then select "ALL" and Copy / Paste into Notepad.exe and File > Save As .fpx and open the file in the PCB Footprint Expert.
As long as the "Header" and "Column Attribute" names are in the proper place.
I create a lot of my FPX file data in Excel because I like the editing features.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2012 at 9:01am
Can you send us CSV samples so we can see the different formats? Maybe we can add a new "Export to CSV File" feature.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evenkeel Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2012 at 10:05am
Thanks for the reply.
I should have opened the FPX file with notepad just to explore.  Since it is already in a text format, then grep will work very well without exporting from Excel to CSV (comma separated values).
It is interesting to note that you use Excel as an editor.  I will have to keep that in mind.
