Forum Home Forum Home > Libraries > Schematic Symbols > CADSTAR
  New Posts New Posts RSS Feed - Create Pin List (CSV)
Message Reverse Sort Order
Mattylad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattylad Quote  Post ReplyReply Direct Link To This Post Topic: Create Pin List (CSV)
    Posted: 23 Dec 2012 at 5:25pm
In the help search for
Aldec .csv Information
If you cannot figure it out from that post back and I'll find an example file when I return to work in the new year.
By having a good pin list it allows you to import all the gates, pins, pin side - pin labels etc into your symbols within the block wizard, which then allows you to output a multigate file which can be imported during part creation to fill in all the pin mapping and labels.
This enabled me to make a 1760 pin BGA part with about 40 symbols in under 30 minutes Big smile
Took a heck of a lot longer to check and validate it all.
frape View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frape Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2012 at 2:06am
Hi forum users,
when I create a new schematic symbol for a MCU using the block wizard I have to spend a lot of time in order to write on my own the pin labels. Sometimes the number of pins is about 100. I have seen that Cadstar gives the opportunity to import a pin list written in a csv format but I cannot find an example.
Does somebody know how this csv file should be written?
Thanks in advance for your help!!!
This page was generated in 0.229 seconds.
