Create Footprint Window |
Page <123> |
| Author | ||
chrisa_pcb
Moderator Group
Joined: 29 Jul 2012 Location: San Diego Status: Offline Points: 772 |
Posted: 25 Feb 2015 at 10:42am |
Easy enough to drop-in. I'll give it a try. Thanks.
chrisa_pcb
Moderator Group
Posted: 25 Feb 2015 at 12:53pm |
Does that return a TLayer object which is then provided to the .Layer of the element being built? I assume the proper terminology from our script would be: CurrentLib.Board.LayerStack_V7.LayerObject_V7[ILayer.MechanicalLayer(i)] as a .Board only exists within CurrentLib. Edit: I tried manual editing to set a track layer per your setup and it doesn't recognize a LayerStack_V7 property.
robmeyer
Posted: 26 Feb 2015 at 2:24am |
This LayerObject things are taken from the attached script. This script is used to manipulate the Designator on the Layer you want.
uploads/870/AdjustDesignators2.zip With this code inserted in your produced script, I could enable and show MechLayer17:
Now is "only" the question how to draw on this layer. Did you have Altium installed to get these things tested? |
chrisa_pcb
Moderator Group
Posted: 26 Feb 2015 at 10:46am |
I do have Altium installed, yes. Thanks for expanding on this.. I'll test your stuff and see about implementing it.
chrisa_pcb
Moderator Group
Posted: 26 Feb 2015 at 12:21pm |
Stack := Board.LayerStack_V7;
I get an undeclared identifier for LayerStack_V7 when I go to run. It simply doesn't recognize it as a property of board. Which version of Altium are you using? I'm currently using v13.3. Is this functionality that was added in a more current version of Altium? |
robmeyer
Posted: 26 Feb 2015 at 12:39pm |
In AD13 the V7 API is not implemented. It is available since AD14. Could be that it also work with Stack := Board.LayerStack;
chrisa_pcb
Moderator Group
Posted: 26 Feb 2015 at 1:18pm |
So basically, to do it it needs to use functionality only found in the latest version of the tool? Not a big fan of that, particularly given I have nothing to test it with.
robmeyer
Posted: 27 Feb 2015 at 5:40am |
I found something, but it is not really nice. You could use something like:
Maybe you have a good idea how to combine LayerStack and LayerStack_V7. All other things are the same. Then the next problem would be how to place Tracks on these Layers. I think it is to much affort to get this work, for a small usergroup. If you want to continue I will do what I can. Robert |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6095 |
Posted: 27 Feb 2015 at 6:24am |
Robert,
We can do anything, but we are not on Altium yearly maintenance and we do not have V14 or V15 of Altium. We're trying to negotiate a deal with Altium to get a couple of new licenses, but we only need the Library Features. We do not do PCB design work in Altium so we don't need part placement, rules, routing, Out Job, etc. So we're not going to pay $10K per seat for features we'll never use. |
robmeyer
Posted: 27 Feb 2015 at 6:44am |
I understand this complete.
The only question on this topic was if you want to go on and pay time on this. Then I could help a little bit. |
Page <123> |
