  New Posts New Posts RSS Feed - Create BGA Footprint With Offset/Staggered Pins
troyschultz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troyschultz Quote  Post ReplyReply Direct Link To This Post Topic: Create BGA Footprint With Offset/Staggered Pins
    Posted: 27 Dec 2018 at 10:28pm
I am trying to use the LE Pro to create a footprint for a part using an WLCSP-64 package.
This has alternating columns of pins offset/staggered.
What do I need to create this footprint and STEP model with the LE Pro?
https://i.imgur.com/UwhkqDG.png
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 7:58am
You can easily build this part in FP Designer in less than 3 minutes, once you know how to do it.
The 3D STEP model will be a simple extruded block that will match your package dimensions and Polarity Marking selection.
Post Options Post Options   Thanks (1) Thanks(1)   Quote troyschultz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 8:22am
Thanks.
Although that works it is quicker/easier to create the footprint with my own workflow in my CAD package than using the FP designer.
I was trying to use the "Create new Surface Mount" tool to get an IPC7351 compliant footprint and reasonable STEP model.
It does everything needed except the ability to set any offset for staggered rows/columns.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 8:25am
V2019 Library Expert will have a staggered row BGA component family that will be IPC compliant and produce a High-quality 3D STEP model.
V2019 will be available in Beta this March.
Post Options Post Options   Thanks (1) Thanks(1)   Quote troyschultz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 8:33am
Thanks.
Good to know this capability will be added in the new version.
Keep up the great work. Library Expert is a nice tool and covers most part needs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 12:37pm
V25.03 Footprint Expert.
Here is the FP Designer Wizard settings for this Staggered Pin BGA.
Here is the finished BGA footprint.
This page was generated in 0.500 seconds.
