  New Posts New Posts RSS Feed - Courtyard Excess for Allegro
mahmoodv99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahmoodv99 Quote  Post ReplyReply Direct Link To This Post Topic: Courtyard Excess for Allegro
    Posted: 01 Feb 2016 at 8:14pm
How to set custom Courtyard Excess for Allegro.
I want to set 0.254 mm excess from assembly outline and pad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 7:58am
Preferences > Terminals > Select any Terminal > Density Level > Courtyard Excess
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahmoodv99 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2016 at 11:52pm
I given in the mentioned settings.
But output not getting as settings value.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2016 at 8:41am
Did you create (Save) your personal Preference file?
Every day Library Expert Users change the Courtyard Excess to zero (0) or some other number.
Just make sure that you select "Save As > Your FileName.dat".
If this does not work, send us your .dat file to support @ pcblibraries dot com and we'll fix it and send it back to you. Just tell us what you want.
