  New Posts New Posts RSS Feed - Controlling Solder Mask & Paste Mask
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Controlling Solder Mask & Paste Mask
    Posted: 02 Nov 2012 at 6:22pm
Currently is there any way to control the pad sizes for the solder mask and paste mask layers when outputting to PADS Layout?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2012 at 7:09pm
PADS Layout has a padstack editor that allows the user to add any layer to any pin. You can over size and undersize the solder mask and paste mask to your liking.
I like to add Assembly Top & Bottom to the padstack so I can selectively add assembly pads to parts I want and remove it (do not add it) for parts I don't.
The PCB Footprint Expert automatically creates swelled solder mask for an entire library or add/delete pads on assembly drawing by simply adjusting the user preferences.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2012 at 7:17pm
I understand you can do that in Pads. My question is what does PCB Footprint expert do for soldermask and solderpaste when it outputs decals to pads ? Are they the same size as the pad ? What do you mean by swelled soldermask ? Are the soldermask created largerthen the pad size ? If so is this size controllable ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2012 at 7:32pm
Yes, the user preferences in every "Setup > Preferences > Terminals > Terminal Type > Settings (tab)" -
This page was generated in 0.688 seconds.
