  New Posts New Posts RSS Feed - Confused College Student
FSPCBA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FSPCBA Quote  Post ReplyReply Direct Link To This Post Topic: Confused College Student
    Posted: 23 May 2022 at 3:30am
This is my first post.
I just graduated from college and entered the printed circuit board industry, but I am not familiar with this industry at all.
I studied public utility management in college, I hope someone can give me some advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2022 at 8:43am
Use metric units for everything using 0.01 mm increments.
  • CAD Library Land Patterns
  • Part Placement in 0.10 increments
  • Trace Widths & Routing Grid
  • Via Pad & Hole Sizes
SteveASmith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveASmith Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2022 at 10:29am
Good luck! you're about to take a drink of water from a fire hose.
Join the IPC Designer's Council online at IPC.org and hopefully there is an active chapter in your area. If there is you will get plenty of advice.
Also, join a user group for the software you are using. There will be a lot of help from them as well.
My regards,
Steve Smith
