  New Posts New Posts RSS Feed - Component placement and courtyard
dwaltoneng View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwaltoneng Quote  Post ReplyReply Direct Link To This Post Topic: Component placement and courtyard
    Posted: 10 Apr 2013 at 3:13pm
Is the minimum component spacing relative to the outside of courtyard line or the center? Is it ok for the courtyard lines to overlap, if the center of the lines does not overlap?
For example, a CAPC1608X90N has a courtyard width of 1.48mm to the line centers. Is it ok to place the parts side by side at 1.5mm centers? With a courtyard line width of 0.05mm, the line edges overlap slightly.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2013 at 6:59pm
It's the courtyard centerline (not the line edge).
You can bump courtyard lines so they overlap on top each other. Just don't overlap past the centerline.
