  New Posts New Posts RSS Feed - CM Chip Inductor (4-Lead)
Snakeeater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Snakeeater Quote  Post ReplyReply Direct Link To This Post Topic: CM Chip Inductor (4-Lead)
    Posted: 22 Oct 2014 at 8:51am
Looking for input on constructing the following component:
It is a Common Mode Chip Inductor (4-Pins, 0805)
DLW21SN900HQ2L
I was thinking it would fall into the Chip Array family, or possibly the DFN 4-Lead.
Would someone kindly steer me in the right direction?
Thank you in advance,
Iain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2014 at 10:34am
Murata does not have a recommended pattern in their datasheet -
http://search.murata.co.jp/Ceramy/image/img/PDF/ENG/L0114S0133DLW21S.pdf
I would recommend a 0.1 mm periphery around the component lead.
This part would take 3 minutes to create in the Library Expert "FP Designer".
This page was generated in 1.938 seconds.
