Class A (Most) Land Pattern Extended Pads |
Alex Quilty
Topic: Class A (Most) Land Pattern Extended PadsPosted: 11 Jun 2024 at 7:28am |
Hey everyone,
My understanding for IPC's Class A Land Patterns is that they perform just as well as Class B (Nominal) Land Patterns. I also know that the Class A Land Patterns have been kept for those who may be soldering the component to the PCB by hand. Finally, where I am a little confused, is where a particular Pad may be too small or too big, this could cause issues in manufacturing to IPC Class specifications depending on the size, which leads me to the question: Is it okay to extend my Pads to allow for easier hand soldering? If so, how much longer am I allowed to make these Pads before it degrades the Fillet too much, since the solder would be spreading along the Pad instead of climbing the lead to form the Filet? Edit: I just noticed the Land Pattern Forum section, I can move this there if you would like, otherwise I will leave it here, or if a MOD could move this post, that would be awesome! Let me know if you want me to move it. |
Thanks(1)
Posted: 11 Jun 2024 at 8:30am |
You can't manually solder BTC or Grid Array parts, and Gullwing parts don't require a lot of solder on the Toe. ![]() |
