  New Posts New Posts RSS Feed - Chip Caps and Resistor w/No Terminal Tolerance
pcbfreedomcad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pcbfreedomcad Quote  Post ReplyReply Direct Link To This Post Topic: Chip Caps and Resistor w/No Terminal Tolerance
    Posted: 11 Mar 2026 at 5:14am
What is entered in the tool for L and L1, when there is no tolerance for lead length given in the datasheet?
I am thinking of Chip Capacitor and Resistor terminal tolerances.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2026 at 8:31am
When L and L1 dimensions are the same, only enter L (don't enter duplicate dimensions).
L1 is optional if it's different than L.
I recommend that you open the free SM Discrete.fpx file and sort the Case Code Column.
Then search for similar Case Codes from other manufacturers and see what their Terminal Lead Tolerances are.
Sometimes the component manufacturer will only provide the Minimum dimension and you need to figure out the Maximum dimension.
Average Terminal Tolerances for chip components by Case Code:
  • 01005 - 0.03
  • 0201 - 0.05
  • 0402 - 0.10
  • 0603 - 0.15
  • 0805 - 0.20
  • 1206 - 0.25
  • 1812 - 0.30
