  New Posts New Posts RSS Feed - CFP/CQFP
CFP/CQFP
AGONZ67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AGONZ67 Quote  Post ReplyReply Direct Link To This Post Topic: CFP/CQFP
    Posted: 08 Sep 2015 at 12:08pm
The image shown for CFP and CQFP is shown with gullwing leads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 2:06pm
All CFP and CQFP must have their leads formed with a lead bender to the shape of a Gull Wing lead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AGONZ67 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 2:10pm
Yes, I understand that, but I am looking for information on how to calculate the dimensions, "L" & "E" to enter into PCBLE? Is there a formula for arriving at these dimensions? From the image below, where do I get the information for the bends, the height of the leads, the length of the leads etc to enter into the Library expert?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 2:13pm
The dimensions must come from the assembly shop or manufacturer that is performing the lead bending.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AGONZ67 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 11:56am
Once the dimensions are provided from the assembly shop or manufacturer it is created as either a CFP, or CQFP, which appears to be calculated the same as SOIC, or QFP ? What benefit is provided by having a separate CFP, CQFP entry other than the prefix of the name?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 1:24pm
Because Library Expert outputs perfect 3D STEP models and there is a BIG difference in a black plastic molded QFP and a Ceramic CQFP.
Also, the FPX file "Physical Description" is different and IPC-7351 standard has different categories for these component families.
That's about it.
