  New Posts New Posts RSS Feed - Can't able to place resistor in Allegro pcb design
naveenjoseph View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote naveenjoseph Quote  Post ReplyReply Direct Link To This Post Topic: Can't able to place resistor in Allegro pcb design
    Posted: 16 Jun 2017 at 12:12am
uploads/12386/PICS.rarI am new to ORCAD..  I am trying to design a pcb board using orcad..   Firstly I drawn a schematic in orcad capture.. in my design I am only using..a 2pin connector, an LED and  a resistor..
I designed the 2 pin connector and LED library myself and created the dra and psm files of connector and LED in my project path..
But i didn't designed the resistor because i used the resistor from inbuilt library in orcad - DATACONV. later I annotated my components and created netlist...
then I opened ORCAD PCB designer professional and created a new board in it.. and imported the created netlist. when i am trying to place my components, I could only see my led and 2 pin connector..I can't see my resistor... please find the rar file in which my pictures of project
This page was generated in 0.539 seconds.
