Calculator QFP Pad Stack Invalid Number |
Stadler_s1
Topic: Calculator QFP Pad Stack Invalid NumberPosted: 22 Jun 2016 at 5:33am |
found a little thing here. I Created a 176pin QFP with Datasheet. the Paste Mask Top created a -Size and the Pad Stack Manager says Error. ![]() ![]() |
Jeff.M
Joined: 16 May 2012 Location: San Diego Status: Offline Points: 499 |
Posted: 22 Jun 2016 at 8:05am |
There are couple things that might lead to a negative paste mask value
The b dimension seems pretty small. Are you sure it's 0.08 mm? I checked a few comparable datasheets and the terminal width is typically 0.17 - 0.27. This small dimension with a small side protrusion goal and a shrink on the solder mask could add up to a negative.
Joined: 05 Jan 2012 Location: San Diego, CA Status: Online Points: 6029 |
Posted: 22 Jun 2016 at 8:07am |
The only thing I see that's wrong is the "b" lead width has no tolerance and it should, but that would not cause the error but it will cause a bad Land Pattern Footprint. An insufficient pad width.
Are you using V2016.07? Here is what I get when I enter your dimensions - ![]() |
