Calculation D2PAK |
Post Reply |
Author | |
ThijsVerdonschot
New User Joined: 20 Jul 2012 Location: Netherlands Status: Offline Points: 18 |
Thanks(1)
Posted: 17 Jan 2014 at 5:55am |
I have to calculate a D2PAK footprint from ST Electronics.
In the library expert I only see the option to calculate a TO (DPAK). Is it the best way to use the maximum with for the e1 value since the D2PAK has a kind of a T-shape?
Thanks(1)
I bet the component mfr. recommended pattern is not T-Shape, rather it's a full pad used for thermal relief. You can use the TO (DPAK) component family to create a D2PAK footprint. You can also select the "Footprint" tab and enter the mfr. recommended pattern (after you enter the component dimensions to calculate the IPC pattern). |
ThijsVerdonschot
Thanks(1)
It is an thermal relief pad and the manufacturur recommended shape is 2mm larget then the lagest size. I will use the TO (DPAK) to calculate. Thank you for your quick reply. |
Post Reply | |
Tweet |
