  New Posts New Posts RSS Feed - CAD Translator ME Layer Assignments
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 8:50am
In the Altium Translator menu, the mechanical layer number must be changed.
The word "eMechanical" cannot change or be renamed or you will break the script language.
You can change the Numbers, but not the text
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 8:53am
Chris,
RE: saving new option files.
In the Save As dialog box, navigate (point and click) to a directory where you want your new option file to go.
Where the File name entry appears and is Highlighted, type the new file name.  The ".opt" file extension is added automatically.
Click Save or Cancel to abort.
This is pretty standard procedure for Windows.
ChrisChris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisChris Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 9:12am
Jeff,
I already HAVE the options file. I want to switch to it. I'm asking how to select an already existing options file, not how to create one. Standard Windows "browse to" functionality.
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 10:16am
Sorry, sometimes you have to get slapped in the face to see the problem.
I'm fixing it now and it'll be in a new release in the morning.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisChris Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 10:21am
No worries, and thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 8:39pm
The issue you reported is fixed. Download and install V24.06 pre-release - www.pcblibraries.com/downloads
Let us know if it's OK for official release.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisChris Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 6:39am
Hi Tom, Jeff,
I'm not seeing any change using the installer in the supplied link. I completely uninstalled all other instances of FP Expert to make sure I wasn't opening an older revision by accident. About is showing version v.05.
Clicking the ellipses in the translator still takes me to a Save As dialog.
Perhaps the installer at the provided link is incorrect?
I am stuck in meetings for the next 5 hours but can test any additional update you provide after that.
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 9:11am
You'll need the V24.06 pre-release dated 3/27.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 9:27am
Here are the new Altium Translator buttons to Open & Save Option files:
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisChris Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 11:42am
OK, I think I missed the fine print and didn't explicitly click on this...
Checking it now...
