  New Posts New Posts RSS Feed - CAD Output - Check Box "Set as Default Format"
Batiskaf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaf Quote  Post ReplyReply Direct Link To This Post Topic: CAD Output - Check Box "Set as Default Format"
    Posted: 27 Jul 2017 at 2:15am
I have tried to use the check box "Set as default format" (Create Footprint window - Translator field), but unsuccessful. This doesn't work.
Maybe I'm do something wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 7:44am
To save you CAD tool interface settings, there is a button in the lower right that says -
"Save Entries as Preferences"
Select it after you enter all your data fields.
This saves all your settings to a file in this folder -
C:\Program Files (x86)\PCB Libraries\Library Expert 2017
File Name:
FPXFormatPreferences.xml
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 10:29pm
It works fine. Thanks.
