  New Posts New Posts RSS Feed - Bug with 3D output of SOFL
JeffreyJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffreyJ Quote  Post ReplyReply Direct Link To This Post Topic: Bug with 3D output of SOFL
    Posted: 24 May 2017 at 4:29pm
Hi, I create a transformer using transistor footprint SOFL since it used the same package.  But the XFMR has a slightly rotated pinout which I was able to change for the land pattern.  But when I generated the 3d Step file, the pin 1 marking didn't follow along and is incorrect in the step file.
Please see images below.
If you have any questions, please feel free to contact me.
Jeffrey Jenkins
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 4:33pm
Do you want us to add "Transformer" to the component selection?
Do you want us to add "Pin Rename" to the SOFL component family?
You can move the part to FP Designer and do whatever you want.
But you can use the Calculator to produce a high quality 3D STEP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffreyJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 5:03pm
I don't really need any of those.
What the issue is the pin 1 marking on the Step file output didn't follow the pin 1 on the part when it was mirrored and rotated inside of Library Expert (version 2017.13).
The footprint for xPCB cell was fine, but the STEP file output was incorrect.
This appears to be a bug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 5:08pm
OK, it's a STEP file bug and we will direct that to the correct programmer.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 3:40pm
This issue is now fixed in V2017.14 pre-release - www.pcblibraries.com/downloads
This page was generated in 0.516 seconds.
