Breaking change in 2018.08 |
| Author | ||
SWB01
Topic: Breaking change in 2018.08Posted: 26 Nov 2018 at 12:33pm |
Version 2018.08 made the following change (for Altium):
I would like to disable this. I often make minor changes and additions in Altium after importing the footprints from PCB Libraries. When updating a footprint from PCB Libraries, my normal workflow (prior to 2018.08) was to:
Because 2018.08 overwrites existing footprints, I have to rename existing footprints beforehand if I want to save anything to apply to the updated version. Another approach that would cover most (but not all) of my use-cases would be for PCB Libraries to preserve anything on layers that it doesn't touch. For example, I place my 3D bodies on eMechanical14 and eMechanical24. I do not have PCB Libraries writing anything to these layers. If PCB Libraries would preserve the original contents of (in this example) eMechanical14 and eMechanical24, then that would cover most of my needs. (I would still have to redo the designator, though, since that lives on the same layer as the assembly outline, and it wouldn't help in the few situations where I make more extensive changes.) |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6073 |
Posted: 26 Nov 2018 at 12:40pm |
We're confused about your 3D STEP model layer request.
You can change the 3D STEP layer in the Altium Translator by changing the Layer Number to whatever you want. Then Save Entries as Preferences to save that change. Also, it may be best for you to create a "New Library" when exporting to Altium. Then quality control the result and then Copy/Paste it into your master library. |
SWB01
Posted: 26 Nov 2018 at 1:21pm |
I don't use the 3D models from PCB Libraries. I have my own 3D models, either downloaded directly from the manufacturer's website or created by me in SolidWorks. In PCB Libraries, I've left the layer setting for 3D Model blank. When PCB Libraries overwrites an existing footprint, it erases my custom 3D model. I then have to go find it and re-import it into Altium. If PCB Libraries would preserve anything in an existing Altium footprint on layers that it doesn't write to, then this would address that issue: It could still overwrite the pads, silkscreen, etc., but anything I've done on other layers (including my custom 3D model) would remain untouched. But simply reverting to the pre-2018.08 behavior would also work well for me. There are situations where either approach would be preferable, depending on the nature of the customizations and which layers they live on.
That may work reasonably well. I will give it I try. Thanks for the suggestion. However, could we not have:
