Beware of TI Case Code Package Dimensions |
Post Reply ![]() |
Author | |
Tom H ![]() Admin Group ![]() ![]() Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5809 |
![]() ![]() ![]() ![]() ![]() Posted: 02 May 2018 at 6:11am |
I moved the link into the word "Here" and it seems to work OK.
5not4 ![]() Active User ![]() Joined: 09 Jul 2013 Status: Offline Points: 40 |
Hi Tom.
I get a dead link for the "back door".
Here's a link to the back door of TI Case Code package data - Here
These are PDF files of the physical package dimensions. And it points to over 110,000 links of their Logical Data part numbers that use each specific Case Code. Currently, there are about 90,000 TI part numbers on POD and we're updating the Case Codes as fast as TI changes them, but we cannot globally update all Case Codes on POD due to the variety of different dimensions under the same Case Code number. I wish that all component manufacturers would pick one Case Code number for each set of component dimensions. if the package dimensions are different, then create a new Case Code. I think this is the reason that they indicate "See the next page for Thermal Tab dimensions" and then when you look there are none. |
dsimpson ![]() New User ![]() Joined: 20 Jan 2017 Status: Offline Points: 1 |
At least those 2 drawings had dimensions! I keep running into drawing that say "See next page for Thermal Tab dimension", and then the next page has no dimension data. Have to contact them and wait while they contact someone else! I guess I should be happy that TI returns their their support questions, unlike some companies!
Librarians get no respect. ;-) |
Texas Instruments (TI) is in the process of replacing the old obsolete JEDEC naming convention that they used for the past 30 years for their Case Code assignments. An example of the old TI Case Code is a typical SOIC - D (R-PDSO-G8) where the "D" is assigned by TI and the R = Rectangle, P = Plastic, SO = SOIC, G = Gull Wing and 8 = pin qty. TI acquisitioned National Semiconductor (NS) and they decided that NS had a better Case Code assignment than the JEDEC name. DWV0008A = the new TI Case Code for a 8-pin SOIC Here is an example of a QFN with 3 different Thermal Tab sizes using an identical Case Code - RTE (S-PWQFN-N16) Datasheet Link 1: http://www.ti.com/lit/ds/symlink/ads122c04.pdf ![]() Datasheet Link 2: http://www.ti.com/lit/ds/symlink/tps65632.pdf ![]() Datasheet Link 3: http://www.ti.com/lit/ds/symlink/tps61181a.pdf ![]() |
Post Reply ![]() |
Tweet |
