  New Posts New Posts RSS Feed - Asymmetrical Thermally enhanced "SON"
ransonjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Topic: Asymmetrical Thermally enhanced "SON"
    Posted: 05 Apr 2019 at 12:36pm
Is there / do you plan built in support for parts like http://www.ti.com/lit/gpn/csd25404q3 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 3:23pm
You can easily build this part in Library Expert. maybe 5 minutes.
Start in the SON w/Tab Calculator and enter all package dimensions and select OK.
Then select the Footprint Tab and enter the mfr. recommended pad sizes.
Change the Pad Shape to Rectangle in the Settings tab.
Save the Calculator part to your FPX file.
Move the part to FP Designer to edit the Thermal Pad location and pad stack in the pad stack manager.
When finished, select the Finish tab and fill in the data and save to FPX.
You can overwrite the Calculator part or use the Calculator part for the 3D STEP model.
Or, you can go to POD and search for Texas Instruments Case Code - DQG and download it for free.
This page was generated in 0.563 seconds.
