  New Posts New Posts RSS Feed - Altium Mechanical Layers
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Altium Mechanical Layers
    Posted: 04 Nov 2025 at 6:50am
I setup my Altium output for Mechanical Layers 11, 13, 15 only.
However, when open in Altium it appears extra layer Mechanical 1
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2025 at 7:46am
Hi m.elsayed,
Really interesting issue. We configure our mech stack in PCBFootprint Expert as well...
is this mechanical 1 the Assembly Bottom layer?
Regards.
david
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2025 at 8:24am
Here are the Altium Default Layer Assignments created in November 2024.
These are the Default Layers in Footprint Expert.
Here is the Altium documentation information to their Style Guide:
In your screenshot, you are assigning Mechanical Layer 11 to the Assembly Outline Top and Bottom. This is not recommended that you use the same layer for both Top and Bottom.
You are also assigning Component Outline, Terminal Outline and Reference Designator to Mechanical Layer 11.
Never seen this before and we don't know any professional Altium user who directs all these elements to the same Mechanical Layer 11.
We highly recommended that you use the Altium Default Layer Recommendations.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 1:00am
Tom,
This is a customized layer option we need.
Mechanical layer 1 appears as blank layer however, we don't need it.
It's in the Script.
Can please check?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 9:32am
The FPE Altium translator only writes mechanical layer 1 to the .pas script when a user assigns Altium eMechanical1 to one of the FPE Footprint layers (like 'courtyard' or 'silkscreen').
Unspecified layers will never appear in a translator script.
If you have a question or issue with layer 1 as applies to your Altium application, then you need to contact Altium.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2025 at 4:26pm
Default Altium Layers. Mechanical Layer 1 = Board Shape
Layers in Altium Designer
The following Altium layer mapping is suggested as a standard. This mapping includes the Layer Type settings available in the Edit Layer dialog in Altium Designer for both single mechanical layers as well as for layer pairs. When there are two consecutive similar layers where the first layer begins with TOP…, and the next layer begins with BOTTOM…, these two layers should be used to create a corresponding layer pair in Altium Designer. For example, Mechanical Layer 9, TOP GLUE, and Mechanical Layer 10, BOTTOM GLUE, would be used to create a Layer Pair called GLUE with the Layer Type setting set to Glue Points.
Layer Types make it easier to share Altium Designer data when different layer numbers have been used for the same layer information by different users. For example, one uses Mechanical Layers 13 and 14 for Top and Bottom 3D Bodies, and the other uses Mechanical Layers 14 and 15 for Top and Bottom 3D bodies. 3D body data could potentially be lost when sharing between the two users. However, if both users have assigned the Layer Type of the 3D body to their respective 3D body layer pair, then when loading data from each other, the 3D body data will be mapped to the corresponding layer numbers that match the Layer Type. See Working with Mechanical Layers” in the Altium Designer online documentation for more information.
This layer mapping also includes some basic layers needed for Flex and Rigid-Flex PCB designs.
1-8 Board Related Layers
Mechanical 1
BOARD SHAPE
Overall board outline or profile - Layer Type = Board Shape
Mechanical 2
ROUTE TOOL PATH
Mechanical routing information - Layer Type = Route Tool Path
Mechanical 3
DIMENSIONS
Dimensional detail required for the board - Layer Type = Dimensions
Mechanical 4
HOLE DETAIL
Dimensional detail required for special holes
Mechanical 5
DXF IMPORT
Mechanical details imported from DXF
Mechanical 6
V-CUT
V-Groove or scoring details - Layer Type = V Cut
Mechanical 7
BOARD
Detail board-related instructions or details - Layer Type = Board
Mechanical 8
User defined
9-33 Component Related Layers
Mechanical 9
TOP ASSEMBLY
Detail component package outline for assembly - Layer Type = Assembly
*Can be used by Draftsman
Mechanical 10
BOTTOM ASSEMBLY
Mechanical 11
TOP DESIGNATOR
.Designator special string layer pair - Layer Type = Designator
Mechanical 12
BOTTOM DESIGNATOR
Mechanical 13
TOP 3D BODY
3D model layer pair - Layer Type = 3D Body
Mechanical 14
BOTTOM 3D BODY
Mechanical 15
TOP COURTYARD
Component required placement space layer pair - Layer Type = Courtyard
Mechanical 16
BOTTOM COURTYARD
Mechanical 17
TOP COMPONENT CENTER
Indicate the centroid of the component - Layer Type = Component Center
Mechanical 18
BOTTOM COMPONENT CENTER
Mechanical 19
TOP VALUE
Place the .Comment special string - Layer Type = Value
Mechanical 20
BOTTOM VALUE
Mechanical 21
TOP COMPONENT OUTLINE
Define the area the component occupies on the board - Layer Type = Component Outline
Mechanical 22
BOTTOM COMPONENT OUTLINE
Mechanical 23
TOP COMPONENT DIMS
Define the dimensional detail required for components - Layer Type = Dimensions
Mechanical 24
BOTTOM COMPONENT DIMS
Mechanical 25
TOP GOLD PLATING
Define component selective gold plating requirements - Layer Type = Gold Plating
Mechanical 26
BOTTOM GOLD PLATING
Mechanical 27
TOP GLUE
Component assembly glue points layer pair - Layer Type = Glue Points
Mechanical 28
BOTTOM GLUE
Mechanical 29
TOP CONFORMAL COAT
Component assembly conformal coating details layer pair - Layer Type = Coating
Mechanical 30
BOTTOM CONFORMAL COAT
Mechanical 31
COMPONENT CAVITY
Embedded component cavity definition
Mechanical 32
User defined
Mechanical 33
User defined
34-40 Board Documentation Related Layers
Mechanical 34
FABRICATION NOTES
Detail important fabrication notes - Layer Type = Fab Notes
Mechanical 35
ASSEMBLY NOTES
Detail component load order and/or important assembly notes - Layer Type = Assembly Notes
Mechanical 36
TITLE BLOCK
Detail the drawing title block and sheet border - Layer Type = Sheet
Mechanical 37
TITLE BLOCK MIRRORED
Detail a mirrored version of the drawing title block and sheet border
Mechanical 38
CONTINUATION BLOCK
Detail a simplified drawing title block and sheet border for sheet(s) 2-n
Mechanical 39
CONTINUATION BLOCK MIRRORED
Detail a mirrored version of the simplified drawing title block and sheet border for sheet(s) 2-n
Mechanical 40
User defined
41-48 Panel Documentation Related Layers
Mechanical 41
PANEL DIMENSION
Detail important panel layout dimensions
Mechanical 42
PANEL FABRICATION NOTES
Detail important panel fabrication notes
Mechanical 43
PANEL ASSEMBLY NOTES
Detail important panel assembly notes
Mechanical 44
PANEL TITLE BLOCK
Detail the panel drawing title block and sheet border
Mechanical 45
PANEL TITLE BLOCK MIRRORED
Detail a mirrored version of the panel drawing title block and sheet border
Mechanical 46
PANEL CONTINUATION BLOCK
Mechanical 47
PANEL CONTINUATION BLOCK MIRRORED
Mechanical 48
User defined
49-53 Flex and Rigid-Flex Related Layers
Mechanical 49
TOP PSA
Define areas requiring pressure sensitive adhesive necessary for final assembly
Mechanical 50
BOTTOM PSA
Mechanical 51
TOP STIFFENER
Define areas requiring a stiffener
Mechanical 52
BOTTOM STIFFENER
Mechanical 53
BEND LINES
Detail flex bend lines
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 16 minutes ago at 7:27am
I communicated with Altium and their reply as below. Please advise and support.
"If you create a new footprint (which the script seems to do) or even a new PCB, per default there is a Mechanical Layer 1. But to be honest, all mechanical layers from 1 to 32 are predefined. They already exist. They are not visible in the View Configurations, but they are sort of already there (only visibility is false). So it is basic Altium functionality to have this layer there.
In your Footprint, go to Tools > Export Mechanical Layers. Generate the .stackup file. Now open the stackup file with a text editor. You will find that the Mechanical Layers are there, but visibility is set to false. So there is no issue in having the Mechanical Layer visible.
But to me it seems if you want the mechanical layer to be disabled automatically, make it so in the script that it is removed after the mechanical layers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 13 minutes ago at 9:30am
We don't have any plans on updating the Altium script routine.
It’s a unique custom modification that has never even been suggested by any of our Altium users and may not be benign or welcomed by our Altium customers.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 17 minutes ago at 12:26am
Thanks Tom for great your support
Just not this is not custom modification, M1 is added as blank by defualt when you pcb, file
before strat run scrpit, so supposed  that when scrpit open before load data delet balnk layer which added by default and keep only M layers which result from pcb tool
This page was generated in 0.312 seconds.
