  New Posts New Posts RSS Feed - Allegro Pin Number Centered Size
pzt648485640 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pzt648485640 Quote  Post ReplyReply Direct Link To This Post Topic: Allegro Pin Number Centered Size
    Posted: 24 Feb 2017 at 12:39am
Allegro Pin Number automatically centered, according to the PAD size automatically centered size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 8:37am
I'm not sure we have control to relocate the Pin Numbers.
Can you do that manually? If so, can you send us an Allegro part with the Library Expert default and the same part where you moved the Pin Numbers to your preferred location so we can compare the two.
Also, please send screen shots of before and after.
Thank you.
This page was generated in 4.441 seconds.
