  New Posts New Posts RSS Feed - Allegro Options
Allegro Options
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Allegro Options
    Posted: 14 Dec 2015 at 9:33am
I could not find an explanation of the following on the allegro interface.
Can you please explain what they are used for.
  1. Auto_Confirm SSM Save. I assume this is to keep from overriding existing SSM files?
  2. NO PROBE
  3. EXCESS
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 2:09pm
We will update the Allegro Interface instructions. But in the meantime,
  1. Certain versions of Allegro will pop a confirmation box when a SSM (complex pad stack) goes to save. This option is to auto-confirm it if you have one of those versions. Normally its off and you turn it on if you get annoying confirmation boxes at the end of a complex pad stack save. If you don’t, you’re good.
  2. NO PROBE – This will place a shape on the No Probe layer that will match the selected constraints. The options for constraints are Component Body, the Footprint Extents, or the Courtyard.
  3. EXCESS – This expands or contracts the NO PROBE extents by a static amount in millimeters. Has no effect if there is no NO PROBE area selected.
This page was generated in 0.543 seconds.
