Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 12:15pm
great, so pleas leave chamfer as default, and give user ability to change it with dot, and have parameter control like one in silkscreen,
it will be great if user have ability to choose chamfer or dot in assembly and control dot parameters
and a i know , Tom you are a great support for user and try help all of us ,
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 3 minutes ago at 2:58pm
Tom,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 50 minutes ago at 3:11pm
Your post has received over 4,600 impressions in the past week.
We are currently working on adding a new feature for the Pin 1 Assembly Dot.
It will have a min/max range so that it can scale per the package body width.
It will be located in the corner where Pin 1 is.
The current Assembly Polarity Chamfer will be the default setting to match the current output, but the user can change the chamfer to a dot.
This new feature will take a couple days to code into the Options file and every user will have to update their Option file by opening and saving it.
The next V25.10 pre-release should be available by Monday 9/15/25.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 11 minutes ago at 1:50am
Great Tom
 hope to be added with same parameters like one found silkscreen
