Adding Pin 1 Dot on Assembly Layer |
Page 123> |
m.elsayed
Topic: Adding Pin 1 Dot on Assembly LayerPosted: 03 Sep 2025 at 7:40am |
Rather than having a chamfer corner for the assembly pin 1 polarity marker. Add a Dot on the assembly layer with required parameters to change the size, height text, line width.
Posted: 03 Sep 2025 at 9:47am |
Does anybody else want this feature? Let us know.
tgrodnicki
Thanks(1)
Posted: 03 Sep 2025 at 10:50pm |
Some inductors have a dot on their bodies to indicate polarity. That's how I mark it in my footprints. I do this using the Drawing Elements - Symbol/Shapes tool (icon). If this were to be automated, it would also be helpful to have control over the dot's position.
m.elsayed
Posted: 04 Sep 2025 at 3:42am |
yes, you correct , this point need to be added it will save more by avoiding do it manual for each part, especially not saved in fpx file( if it done by drawing shapes icon)
Posted: 04 Sep 2025 at 8:10am |
Adding Pin 1 Post Assembly Inspection Dots on Silkscreen is automatic.
Turn this feature on in Options > Drafting > Silkscreen. |
tgrodnicki
Posted: 04 Sep 2025 at 10:20am |
We are discussing the dot on the Assembly layer and whether it should be added automatically like for the Silkscreen layer.
Posted: 04 Sep 2025 at 11:34am |
Do you like the Assembly Polarity Dot better than the Chamfer?
Add an Option to switch between the Chamfer or the Dot? Add sizing controls like the Silkscreen Dot for diameter? Where would it go, in the corner of the Assembly Outline (whatever corner pin 1 is) or by Pin 1? How far into the assembly Outline and what about micro footprints? You see how complicated this gets? |
m.elsayed
Posted: 06 Sep 2025 at 11:10pm |
just you add it as option in Assembly layer, with same parameters as one found in silkscreen layer, without removing chamfer
like an new feature
m.elsayed
Posted: 06 Sep 2025 at 11:12pm |
like reference designator, it found twice one in silkscreen , and other in assmebly layer
and user can control any of them, i hope this be like it
Posted: 07 Sep 2025 at 7:48am |
We can't have both the chamfer and the dot.
It will have to be one or the other because they will collide with each other in some cases. |
Page 123> |
