Adding Minimum Annular Ring for Keepout |
Post Reply ![]() |
Author | |
m.elsayed ![]() Active User ![]() Joined: 22 Sep 2016 Status: Offline Points: 38 |
![]() ![]() ![]() ![]() ![]() Posted: Yesterday at 7:41am |
Add a minimum annular ring for keep-out for non-plated holes in 'Tools > Options > Terminals > Through-hole'.
The current method of making the non-plated hole keep-out the same size as the Anti-pad does not work it you need a keep-out clearance larger or smaller than the Anti-pad. |
Post Reply ![]() |
Tweet |
