  New Posts New Posts RSS Feed - Adding Footprint Naming Convention Twice
Post Options Post Options   Thanks (1) Thanks(1)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Adding Footprint Naming Convention Twice
    Posted: 03 Sep 2025 at 7:42am
Add Footprint Naming convention twice.
IPC-7351B For SMD, and IPC-7352 for through-hole.
Right now we can only select one or the other.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 9:38am
When someone picks the IPC-7351B naming convention in Options, the through-hole parts automatically get IPC-7352 footprint names for through-hole.
There’s only one Footprint Naming Convention for through-hole.
When you select IPC-7351B Footprint Naming Convention, it only affects Surface Mount component families.
The Through-hole naming convention is always there and available in IPC-7352 standard.
Post Options Post Options   Thanks (1) Thanks(1)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 11:35am
Thanks Tom
So you to achieve IPC-7351B for surface mount and IPC-7352 for through-hole
Can be done by only 1option file and selecting IPC-7352B and this automatically get IPC-7352 for though hole and this lead no for adding this feature
Please confirm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 11:48am
There is only one Footprint Naming Convention for Through-hole parts.
The IPC-7351B Naming Convention only applies to Surface Mount.
The Through-hole Naming convention was created 20 years ago and finally released in IPC-7352, but it's been in Footprint Expert since 2012.
Post Options Post Options   Thanks (1) Thanks(1)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 11:50am
Thanks Tom
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 11:52am
Yes
Post Options Post Options   Thanks (1) Thanks(1)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 11:57am
Great
Thanks Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 37 minutes ago at 8:35am
when i check PCB Libraries naming conventions , what IPC  standard naming will be applied for through hole parts?
