Adding Footprint Naming Convention Twice |
m.elsayed
Thanks(1)
Topic: Adding Footprint Naming Convention TwicePosted: 03 Sep 2025 at 7:42am |
Add Footprint Naming convention twice. IPC-7351B For SMD, and IPC-7352 for through-hole. Right now we can only select one or the other. |
Thanks(1)
Posted: 03 Sep 2025 at 9:38am |
When someone picks the IPC-7351B naming convention in Options, the through-hole parts automatically get IPC-7352 footprint names for through-hole. There’s only one Footprint Naming Convention for through-hole. When you select IPC-7351B Footprint Naming Convention, it only affects Surface Mount component families. The Through-hole naming convention is always there and available in IPC-7352 standard. |
m.elsayed
Thanks(1)
Posted: 03 Sep 2025 at 11:35am |
Thanks Tom
So you to achieve IPC-7351B for surface mount and IPC-7352 for through-hole Can be done by only 1option file and selecting IPC-7352B and this automatically get IPC-7352 for though hole and this lead no for adding this feature Please confirm |
Thanks(1)
Posted: 03 Sep 2025 at 11:48am |
There is only one Footprint Naming Convention for Through-hole parts.
The IPC-7351B Naming Convention only applies to Surface Mount. The Through-hole Naming convention was created 20 years ago and finally released in IPC-7352, but it's been in Footprint Expert since 2012. |
m.elsayed
Thanks(1)
Posted: 03 Sep 2025 at 11:50am |
Thanks Tom
So you to achieve IPC-7351B for surface mount and IPC-7352 for through-hole Can be done by only 1option file and selecting IPC-7352B and this automatically get IPC-7352 for though hole and this lead no for adding this feature |
Thanks(1)
Posted: 03 Sep 2025 at 11:52am |
Yes
m.elsayed
Thanks(1)
Posted: 03 Sep 2025 at 11:57am |
Great
Thanks Tom
m.elsayed
Posted: 10 May 2026 at 8:35am |
When I check PCB Libraries Naming Convention, what IPC standard naming will be applied for through-hole parts?
Posted: 10 May 2026 at 2:18pm |
The PCB Libraries Naming Convention includes IPC-7352 for through-hole.
IPC-7351B naming convention for Surface Mount is very close to IPC-7352. IPC-7352 naming convention for surface mount was enhanced to include Thermal Pad, Terminal Lead and BGA Ball Diameter data. I would not use IPC-7351B for anything, including the mathematical model, solder joint goals, and naming conventions. 7351B is 16 years old and obsolete. |
