Add SOT89-3 & 5 Pin Versions to IPC Calculator |
stampedeboss
Thanks(1)
Topic: Add SOT89-3 & 5 Pin Versions to IPC CalculatorPosted: 31 May 2015 at 1:54am |
With more uses of the SOT89-5 package in voltage related chips, can it be added to where the Expert Lite version can create the footprint?
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6069 |
Posted: 31 May 2015 at 6:17am |
You can order any SOT89 here - www.pcblibraries.com/pod
We will also add SOT89 to V2016 as a standard component family. |
stampedeboss
Posted: 16 Jun 2015 at 8:09am |
Problem with POD is finding the SOT89-5 footprint. The component I need it for is not listed:
POW PT4115B I don't know which manufacturer to select. Thank you for the V2016 update. |
Nick B
Posted: 16 Jun 2015 at 8:43am |
Thanks for your comments, we're working on enhancing the PCB POD experience.
PLTcbv
Joined: 21 Aug 2012 Location: the Netherlands Status: Offline Points: 134 |
Posted: 16 Mar 2016 at 7:13am |
Just checked the 2016.02 LITE version but no SOT89 component family.
In which 2016 wil it be implemented?
Posted: 16 Mar 2016 at 7:23am |
SOT89 has a irregular shape pad and the unique pad feature is going into V2017.
