  New Posts New Posts RSS Feed - 2012.47 Released
2012.47 Released
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.47 Released
    Posted: 11 Mar 2013 at 4:00pm
Version 2012.47 has just been released! Yes, 2013 is a bit delayed, but the wait will be worth it!! Get a license now and you will get all 2013 updates as well!  For more details: www.PCBLibraries.com/FPX
FIXED:
  • Calculator – SODFL Footprint Name
  • Calculator – Placement Courtyard for PQFN
  • Calculator – TH part names changed so lead width is the max dimension
  • Calculator – Pad stack manager was unstable when opening
  • Librarian – Updating Molded Body parts in FPX deleted the Mfr. Name
  • CADSTAR – Fixed a bug with the origin not being applied for poly drafting elements
  • OrCAD PCB – ‘Confirm Loss of Accuracy’ has been carried into OrCAD PCB
  • PADS – Solder Mask and Paste Mask associated copper for D-shape pads
  • Pulsonix – Made sure a rogue UI element went away
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2013 at 1:08pm
A new 2012.47 build addresses the following:
  • CADSTAR – The level (i.e. L, M, N, A, B, C, P) will now be depicted in the second field of the symbol definition rather than as the last letter of the Name
  • CADSTAR – The Documentation Layer on layer 22 now is properly set as a Doc layer
  • Pulsonix – Made sure a rogue UI element went away on older versions of Windows
  • McCAD – Added Courtyard as a layer and set it to 10 per the CAD Vendor’s suggestion
The link above will get this latest build.
This page was generated in 0.445 seconds.
