  New Posts New Posts RSS Feed - 2012.39 Released!
2012.39 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.39 Released!
    Posted: 13 Jan 2013 at 5:25pm
Version 2012.39 has just been released!
FIXED:
  • DFN 3-Pin – Was not calculating the correct pad size for the large pin
  • Headers – relocated “Required Entry” for terminal width from Min to Max cell
  • Allegro – Fixed the problem that was causing inner layers for through-hole padstacks to import improperly
  • Allegro – Design parameters was causing the part to be drawn off the bounds of the specified drafting area
  • Allegro – Assembly Top and Assembly Bottom are now permanently suppressed in the padstack
  • CADSTAR – Fixed a problem that was causing the .CSV to lose its alphanumeric pins
  • CR5000 – For SMD Pads, the Top layers are now properly mirrored to the Bottom layers
  • CR5000 – PenType for lines is now set to be Rounded ends by default
  • CR5000 – Added the ability to provide a custom name for the Hole Layer via the UI
  • Expedition – Fixed some problems that were causing admin to fail
  • Expedition – Fixed a bug that was causing through-hole parts to fail
  • FPX File Update – Created new BGA FPX in IPC folder and updated SM & FPE FPX files
NEW:
  • DFN 2-pin – Added Inductors, Resistors and Capacitors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2013 at 9:36am
We just uploaded a new 2012.39 build to fix the following issues:
  • CADSTAR – Text strings for ref des/comp name will be suppressed; instead, the normal Component string facility for CADSTAR will take over
  • PADS ASCII - some issues that were causing PADS ASCII output (all variants) to fail on parts with Rectangular Pad Shape
