  New Posts New Posts RSS Feed - 2012.35 Released!
2012.35 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.35 Released!
    Posted: 08 Dec 2012 at 3:46pm
Version 2012.35 has just been released!
FIXED:
  • Through-hole Flanged Mount (TO-220) Vertical issues
  • Connector dimensional picture would disappear when opening a part from an FPX file
  • Axial Resistor footprint name
  • EAGLE – Regular rectangular pins to use their own built in solder mask and solder paste rather than trying to generate their own
  • CADSTAR – Used the PC# designation for calling out padcodes. This should allow people to paste in their own naming, which may have spaces (the primary issue), for padstacks
  • Allegro – Added a V16.6 selection for OrCAD PCB and Allegro
  • Rounding issue for Padstack naming that was causing conflicts when outputting parts in the Least Configuration when using tools that consolidate padstacks
  • Issue where the Inner Layers label and textbox were being displayed on multiple translators for which they weren't applicable
  • Pin Grid Array ref des not placed at centroid
  • Library Parts – added or repaired all datasheet web-links in the “FPE” .fpx file
NEW:
    • HASP USB key license now available, allows users to easily move license. Existing Fixed Node licensed users can change their license - contact us!
    • Batch Build Library Preferences dialog box
    • CADSTAR – Added a version combobox - there will be two selections once V14 is released: V14 and Legacy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2012 at 7:56am
If you had problems downloading 2012.35 earlier, please try again...
This page was generated in 0.500 seconds.
