  New Posts New Posts RSS Feed - 2012.16 Released!
2012.16 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.16 Released!
    Posted: 25 Aug 2012 at 8:14pm
Version 2012.16 has just been released!
V2012.16 Fixes & Updates:
  • Footprint Expert GUI – Select Pins with “click drag window”
  • PADS Layout – Removed “Thermal Pad” paste mask in padstack
  • CADSTAR – Courtyard Layer
  • OrCAD PCB/Allegro
    • Polygons placed on the PLACE_BOUND_TOP will now properly be Shapes instead of Lines
    • Height and Description attributes will output properly
    • Mechanical Pins are now properly recognized
    • Custom Layer Names will now properly generate a subclass
    • V15.7 is now being handled properly
    • Deleted Pins are now being filtered properly
  • OrCAD PCB activation license code gives wrong result
  • Renamed “OrCAD PCB Editor” to “OrCAD PCB”
New
  • Pin Rename for SOT’s, SOD’s, SOFL’s, Chip, MELF’s & Molded diodes and LED’s, DFN’s and DPAK’s. Pins can be “Renamed” for example ‘E, B, C’ or ‘G, D, S’ or ‘A & C’ in an SOT23 by selecting a pin, “Right Mouse Button > Properties” and entering a new Alphabetical Character name.
  • Added Expedition interface
  • Added Eagle interface
  • Updated “Build Current Footprint” Icon
  • Add new folder IPC folder “PCB Libraries\FPX_2012\Libraries\IPC\BGA.fpx” with 970 BGA packages, per IPC request
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 7:47am
Pin Reorder was released in V2012.16 -
Here is an example of SOT23 -
The Pin Renumber will be added in the V2012.17
This page was generated in 1.016 seconds.
