  New Posts New Posts RSS Feed - 008004 land pattern dimensions for high yield
ransonjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Topic: 008004 land pattern dimensions for high yield
    Posted: 13 Jun 2024 at 7:34am
I'm going to be using 008004 (0201 metric) capacitors in an ultra-small design.
I'd like to get as high assembly yield as possible, and I was wondering if there were any recommended low-defect land patterns?
I've seen a number of papers on 01005 land patterns, but I haven't seen similar for 008004.
I want as many data points as I can get.
I have requested guidance from my assembler, and Murata provides a recommended range of dimensions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 7:50am
For anyone else looking, I found this IPC APEX presentation from Fuji:
https://www.ipc.org/system/files/technical_resource/E40%26S06_03%20-%20Scott%20Wischoffer.pdf
SDTKO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SDTKO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2024 at 1:29am
The only sane thing to do in this case - as you already figured out - is talking to your assembler.
For small chip packages, chances are that generic calculators and general recommendations do more harm than good.
