  New Posts New Posts RSS Feed - PCB Expert Feature Missing?
Alex Quilty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex Quilty Quote  Post ReplyReply Direct Link To This Post Topic: PCB Expert Feature Missing?
    Posted: 22 May 2026 at 10:38am
In the past I was able to click Demo for a particular pattern and adjust all of the dimensions to see the result but not change density or other options (due to no license, ie free use).
I can no longer do this though. Was this intended?
Is it possible for those of us using the free features of the software to get this feature back?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2026 at 10:58am
Are you using the free V26.05 Footprint Expert Calculator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex Quilty Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2026 at 11:24am
Yes I installed the latest version this morning.
So when I click "Demo" on say the Chip land pattern in Surface Mount, I use to be able to change just the dimensions of the Chip calculator and now they are greyed out and do not allow change.
Unless I am installing the wrong edition?
https://www.pcblibraries.com/Downloads/FPX!Footprint_Expert_26-05_Calculator.asp
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2026 at 11:30am
Are you sure you got this?
We don't show that you are using this licensed product.
We tested that all features are working as intended.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex Quilty Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2026 at 11:46am
Ah! I figured it out.
I didn't realize that I needed to activate it with the code on the download page..
Sorry Tom, and thank you for your time and help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex Quilty Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2026 at 1:18pm
Hey Tom, I have one more question. I have some sample FPX Library files from some time ago, and I am able to see them in Footprint Expert 26 but I cannot select them for view like I use to be able to do. All the options to view, search, filter etc. are all greyed out. Any ideas why it is greyed out?
This page was generated in 0.532 seconds.
