  New Posts New Posts RSS Feed - Silkscreen to Pad Clearance
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Silkscreen to Pad Clearance
    Posted: 8 hours 51 minutes ago at 7:27am
If I make the 'Clearance to Pad' 0.178 as image below what impacts?
Also 'Outline to Body Margin' what this parameter do?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 31 minutes ago at 7:47am
You can't use both Clearance to Pad and Outline to Body Margin at the same time.
It's one or the other.
There is a 'Map Outline to Body' to dropdown menu selection with these Options:
  • None
  • Minimum
  • Nominal
  • Maximum
  • +Margin (select this to turn on Outline to Body Margin)
When you select +Margin, then the Outline to Body Margin value is applied.
