  New Posts New Posts RSS Feed - PCB Model Select Radial (Dipped) Rect. 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: PCB Model Select Radial (Dipped) Rect. 1
    Posted: 12 Feb 2026 at 11:14am
For this part” 224MKP275KBG4” in this datasheet “"
Is it  “Radial (Dipped) Rect.”?  Correct or wrong,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:09am
This is the 'Radial (Disk) with Offset Leads'
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 9 minutes ago at 12:39am
please add more details , as i noted
this radial Disk With offset Leads and it's Box Type (rectangular body) Not radial  and this Model not similar the shape of Part in Datasheet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 1 minutes ago at 11:47am
We recommend that if the Radial (Dipped) Rect. w/Offset Leads 3D STEP does not look correct, then build the footprint from scratch in FP Designer.
This page was generated in 0.938 seconds.
