  New Posts New Posts RSS Feed - Paste Mask Question
Paste Mask Question
vavouris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vavouris Quote  Post ReplyReply Direct Link To This Post Topic: Paste Mask Question
    Posted: 24 May 2018 at 5:50am
I'd like to ask what is the general guideline for paste stencils.
Should the stencil be same size as the pad, smaller or greater?
I know that in BGA packages we want very few solder paste on the pad. And on other packages, I was creating a paste mask figure 70% of the pad.
I am a bit confused now, and I don't know if should continue to do that or leave it 1:1 and let the assembly plant deal with it.
Theocharis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 6:08am
For Standard SMD pads the Paste Mask aperture size is 1:1 scale.
For Thermal Tab pads the Paste Mask Reduction is between 40 - 60%.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vavouris Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 6:15am
Thank you! That was fast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 6:19am
If you use Rectangle Pad Shape, the Paste Mask aperture will be Rounded Rectangle, so you might as well use Rounded Rectangle for the pad shape too.
