Odd Mounting Hole |
Post Reply |
Author | |
budnoel
Active User Joined: 16 Mar 2012 Status: Offline Points: 17 |
Posted: 10 Aug 2012 at 6:59am |
Hello - I need to create a mounting hole for a pin that requires two PTH's, a smaller one within the pad of a larger one. I attempted to create a symbol using two padstacks and when I placed the second one I created a DRC error due to the overlapping of the two pads. Anyone have any suggestions for how to create this symbol? I've included a small section of the mfr dwg. to illustrate the issue. Thanks in advance for any help. |
rdl86626
Advanced User Joined: 20 Jul 2012 Location: Hollister, CA Status: Offline Points: 83 |
Notes 3 and 4 are missing. Maybe use 1 padstack and a fill for the other. Do you have a pic of it? Rick
budnoel
Note 4 indicates that there is a pad on top and bottom of pcb but it doesn't give the size. Note 3 indicates what the angle of rotation for location of the second hole. I created a 10.02 pad with a 5.15 hole for the first padstack and made it a pin. The second smaller hole I simply created a 2.55 diam hole and placed it accordingly. That seemed to work. Thanks for the response.
Naveed Khan
Active User Joined: 12 Mar 2013 Location: India Status: Offline Points: 20 |
Post Reply | |
Tweet |
