  New Posts New Posts RSS Feed - PTH Minimum Annular Ring
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: PTH Minimum Annular Ring
    Posted: 10 hours 43 minutes ago at 5:00am
Minimum annular ring is defined in the Options > Terminals > Through-hole
When set to 0.40 mm, does it mean no value than this will be create for any part?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 1 minutes ago at 8:42am
The Hole Diameter for round PTH terminal leads is Max Lead Diameter X 0.20 mm.
The Hole Diameter for rectangle PTH terminal leads is Max Lead Diameter X 0.15 mm.
The default pad diameter is 1.5 times the Hole diameter but you can adjust all these values.
The annular is proportional.
A 1.00 mm hole = 1.50 mm pad = 0.25 mm annular ring.
A 2.00 mm hole = 3.00 mm pad = 0.50 mm annular ring.
A 3.00 mm hole = 4.50 mm pad = 0.75 mm annular ring.
The Minimum Annular Ring of 0.40 is very robust for tiny PTH packages with fine wire terminal leads (like watch crystals). The pad size would be excessive.
Minimum is intended for the smallest terminal lead and hole like a Tuning Fork Crystal.
the terminal lead diameter is 0.20 mm and the hole size would be 0.40 mm diameter. A 0.40 minimum annular ring would be a 1.20 mm pad diameter.
The pin pitch is only 0.45 mm.
This is an example where a 0.40 mm minimum annular ring would be too robust. Too much solder for a tiny hole.
