  New Posts New Posts RSS Feed - IPC-7352 Through-hole Naming Convention
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7352 Through-hole Naming Convention
    Posted: 2 hours 24 minutes ago at 7:24am
Could you please share the document that Footprint Expert uses for the Through-hole Naming Convention?
I found some examples not found in shared document like the attached Varistor:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 55 minutes ago at 7:53am
The Naming Convention and many other documents and free FPX files are located here:
However, IPC-7352 does not cover every component family in the industry. That was intended for IPC-7351C which never got released.
PCB Libraries added all the standard packages to Footprint Expert.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 45 minutes ago at 8:03am
I checked the document but I can't find examples like Variators in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 32 minutes ago at 8:16am
You will not find all the standard packages in the IPC-7352 guideline.
Here's an example of what you will not find for Chip Packages:
  1. Antenna
  2. Choke
  3. Crystal
  4. Ferrite Bead
  5. Filter
  6. Fuse
  7. LED
  8. Thermistor
  9. Varistor
I think you're asking us to add all the missing through-hole component families in IPC-7352 guideline to our Naming Convention document.
The reason why we don't is because we would have to rename the document from IPC-7352 to PCB Libraries.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 3 minutes ago at 9:45am
Just we need naming conventions tool used for these packages
You can share document for this with name you prefer so users can know
