  New Posts New Posts RSS Feed - IPC-7352 Naming Convention
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7352 Naming Convention
    Posted: 4 hours 6 minutes ago at 7:24am
Could you please share the document that Footprint Expert uses for the Through-hole Naming Convention?
I found some examples not found in shared document like the attached Varistor:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 37 minutes ago at 7:53am
The Naming Convention and many other documents and free FPX files are located here:
However, IPC-7352 does not cover every component family in the industry. That was intended for IPC-7351C which never got released.
PCB Libraries added all the standard packages to Footprint Expert.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 27 minutes ago at 8:03am
I checked the document but I can't find examples like Variators in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 14 minutes ago at 8:16am
You will not find all the standard packages in the IPC-7352 guideline.
Here's an example of what you will not find for Chip Packages:
  1. Antenna
  2. Choke
  3. Crystal
  4. Ferrite Bead
  5. Filter
  6. Fuse
  7. LED
  8. Thermistor
  9. Varistor
I think you're asking us to add all the missing through-hole component families in IPC-7352 guideline to our Naming Convention document.
The reason why we don't is because we would have to rename the document from IPC-7352 to PCB Libraries.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 45 minutes ago at 9:45am
Just we need naming conventions tool used for these packages
You can share document for this with name you prefer so users can know
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 59 minutes ago at 10:31am
The Footprint Naming Convention for all Chip packages is the same format.
Component Family Abbreviation + Package Type + Body Length X Body Width X Height + Lead Width.
Component Family Abbreviations:
  • ANT - Antenna
  • CAP - Capacitor
  • CAPP - Capacitor, Polarized
  • CHOKE - Choke
  • XTAL - Crystal
  • DIO - Diode
  • DION - Diode, Non-polarized
  • BEAD - Ferrite Bead
  • FLTR - Filter
  • FUS - Fuse
  • IND - Inductor
  • LED - Light Emitting Diode
  • RES - Resistor
  • THRM - Thermistor
  • VAR - Varistor
Package Types:
  • C - Chip
  • M - Molded Body
  • DFN - Dual Flat No-lead
  • MELF - Metal Electrode Leadless Face
  • SC - Side Concave
  • AD - Axial Diameter
  • RR - Radial Rectangle
Copy / Paste this into your own document.
